Hello,
I want to extend the internet from my main router by using my WRT54G V5, but I want the extended network to be segemented from the main, with its own WiFi SSID and PW and not be able to access computers from the main router.
I ran an ethernet cable from the LAN port on my main router to the Internet port (WAN) of my Linksys WRT54G V5. I reset the Linksys to default settings and only changed one option, the Local IP Address from 192.168.1.1 to 192.168.2.1, to avoid conflicting with the main router that is also 192.168.1.1.
I went to 192.168.2.1 and checked the Status > Router page and it shows it received an IP address from the main router, but I cannot access the internet:
Login Type: Automatic Configuration - DHCP
IP Address: 192.168.1.137
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
DNS 1: 192.168.1.1
DNS 2: blank
DNS 3: blank
MTU: 1500
I thought maybe DNS wasn't working to resolve URL's, so under Setup > Basic Setup I tried switching Internet Connection Type from DHCP to Static IP and added the 8.8.8.8 to DNS 1, but internet still won't work.
Your help is greatly appreciated. Thank you.
DNS 1: 192.168.1.1
DNS 2: blank
DNS 3: blank
MTU: 1500
