Lisandro Heinzmann
Hi everyone. I´m posting this thread because, even though I searched and got some answers, I think I will be better off explaining my particular situation.
I´m trying to stream 4k content to my Nvidia Shield over the network, with plex, and a few seconds after the video starts, I get a message saying that my connection is not good enough to stream this quality.
My setup is as follows.
I have a 100 Mbps down 8 Mbps up connection. My computer (where I have the content) is connected via ethernet to a D-Link DIR-860L router (which I got of a recommended list on the Shield website). In the living room (which is at, roughly, 10 meters away with a wall between it and the router) I have a Lynksis RE2000 range extender and I have an Nvidia Shield connected, via ethernet, to said extender.
Using a test app that checks the connectivity between the Shield and my PC, I get the following results:
Bandwidth (Mbps): 31.22
Frame Loss (%): 0
Jitter (ms): 12
Ping (ms): 3
I checked for this results on different occasions as soon as I got the message from plex so I'm assuming that was the network status when I got the error (The values would be slightly different each time, but nothing mayor).
Also, if I play 4k content through netflix or youtube, I have no problems at all.
I would like to know if you can identify the weak point in my setup. I'm travelling to USA in a few months and I'm planning on getting an ASUS RT-AC88U but I'm afraid to make that change and then not solve the real problem.
Do you guys think my router is the problem? Should I do something different?
I really appreciate any feedback you can give me on this matter. Regards!
Frame Loss (%): 0
Jitter (ms): 12
Ping (ms): 3
