Wired our house when we moved about 9 years ago with cat5e cable. Older house with lathe and plaster walls and stone. It's home run wired to central closet but it seems that we can only get 10/100 over the connection. No run should be more than 20M. Everything looks to be wired T568B but since I did it myself could be flawed.
Can't find the old spindle for the wiring - but jacket wiring says ACOM category 5e enhanced eagle 24awg.
I have placed my new main computer, cable modem (gigabit speed), in my main office to get the full speed and run from the modem back to the home-run area a switch to serve rest of house at lower speed.
Assumed that 10/100 was because it was cat5 cable and just cursed myself for not planning earlier and ordering Cat6 (not available locally at the time). Bit of research suggests that cables should be capable of running 100/1000.
Been mainly using AC wifi from cable modem (Hitron Coda) to serve house (chromecast ultra, laptops etc) as of late but lose AC signal pretty fast.
Tested cat 5e cable from main computer area to homerun area with cheap NS-468 cable tester. Seems that all 1-8 ports flash green in sequence. had same issue whether keystone or RJ45 plug at main computer end. Tried long monoprice cat 6 cable from cable modem to switch which does in fact connect to cable modem/router at 1,000).
The real issue is that signal basically dies in one bedroom and the den for which we need stronger signal would love advice on the following:
1. anyway to get existing wiring up to 100/1000 speeds. reopening walls is not an option or fishing new cable. Putting on new end points/keystones or wallplates is option.
2. do I run access point extender off hard wire even though it is 10/100 speed?
3. do i use power system have TP-link AV500 available to get to office
4. Do i just give up on wired network and go with mesh system - can get a pretty good deal on amplify HD setup
Thank you so much for your help in advance.
