I just upgraded to the N66U and immediately installed Merlin's latest build.
Its all running well but I have some wierd things happening and wondered if someone smarter than me can point me in the right direction.
Background: upgraded from Netgear WNDR3700 v1. Used same SSID as old router and tried to configure other things the same. Opened two ports for forwarding for remote access for server (port 3389) and VPN to win 7 (port 1723)
Issues:
1. No apple client on the wireless network can download any apps (iphone, ipad, ipod). Its as if whatever port used is blocked. But I turned off the routers firewall but that didn't help. I have been able to update through tethering to cellular network subsequently so its not the clients. Does anyone have a suggestion where I should look?
2. I am using dyndns to access my server. I use VPN setup on the win 7 machine. So I connect to xxx.dyndns.org and then forwarded to port 1723. Strange thing is that I can only do this if on the local network, although I am first directing my VPN request to xxx.dyndns.org. If I attempt to connect to my VPN from outside the network, such as on 3G it doesn't go through - it doesn't even get to authentication stage. I assume I still need to do the port forwarding as I want it to go to my server's IP on my lan. I also have the PPTP VPN passthrough enabled on the other tab.
I am finding this quite confusing and would appreciate any suggestions or insights as to what I am doing wrong.
Justin
Issues:
Justin
