I see a lot of messages like this in my logs.
I believe they are just spam but would like confermation from the community... thanks.
Dec 6 01:11:01 ovpn-server1[2345]: 185.200.118.84:51843 TLS: Initial packet from [AF_INET]185.200.118.84:51843, sid=12121212 12121212
Dec 6 01:12:01 ovpn-server1[2345]: 185.200.118.84:51843 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Dec 6 01:12:01 ovpn-server1[2345]: 185.200.118.84:51843 TLS Error: TLS handshake failed
Dec 6 01:12:01 ovpn-server1[2345]: 185.200.118.84:51843 SIGUSR1[soft,tls-error] received, client-instance restarting
Dec 6 03:32:02 ovpn-server1[2345]: 167.248.133.26:37796 TLS: Initial packet from [AF_INET]167.248.133.26:37796, sid=4d658221 07fcfd52
Dec 6 03:32:17 ovpn-server1[2345]: 167.248.133.55:36034 TLS: Initial packet from [AF_INET]167.248.133.55:36034, sid=c001cc78 6da6686a
Dec 6 03:33:02 ovpn-server1[2345]: 167.248.133.26:37796 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Dec 6 03:33:02 ovpn-server1[2345]: 167.248.133.26:37796 TLS Error: TLS handshake failed
Dec 6 03:33:02 ovpn-server1[2345]: 167.248.133.26:37796 SIGUSR1[soft,tls-error] received, client-instance restarting
Dec 6 03:33:17 ovpn-server1[2345]: 167.248.133.55:36034 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Dec 6 03:33:17 ovpn-server1[2345]: 167.248.133.55:36034 TLS Error: TLS handshake failed
Dec 6 03:33:17 ovpn-server1[2345]: 167.248.133.55:36034 SIGUSR1[soft,tls-error] received, client-instance restarting
Dec 6 21:06:14 ovpn-server1[2345]: 80.82.77.33:26876 TLS: Initial packet from [AF_INET]80.82.77.33:26876, sid=d9ce3abe f698a56d
Dec 6 21:06:14 ovpn-server1[2345]: 80.82.77.33:58120 TLS: Initial packet from [AF_INET]80.82.77.33:58120, sid=d9ce3abe f698a56d
Dec 6 21:06:29 ovpn-server1[2345]: 80.82.77.33:51598 TLS: Initial packet from [AF_INET]80.82.77.33:51598, sid=d9ce3abe f698a56d
Dec 6 21:06:44 ovpn-server1[2345]: 80.82.77.33:43592 TLS: Initial packet from [AF_INET]80.82.77.33:43592, sid=d9ce3abe f698a56d
Dec 6 21:07:14 ovpn-server1[2345]: 80.82.77.33:26876 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Dec 6 21:07:14 ovpn-server1[2345]: 80.82.77.33:26876 TLS Error: TLS handshake failed
Dec 6 21:07:14 ovpn-server1[2345]: 80.82.77.33:26876 SIGUSR1[soft,tls-error] received, client-instance restarting
Dec 6 21:07:14 ovpn-server1[2345]: 80.82.77.33:58120 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Dec 6 21:07:14 ovpn-server1[2345]: 80.82.77.33:58120 TLS Error: TLS handshake failed
Dec 6 21:07:14 ovpn-server1[2345]: 80.82.77.33:58120 SIGUSR1[soft,tls-error] received, client-instance restarting
Dec 6 21:07:29 ovpn-server1[2345]: 80.82.77.33:51598 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Dec 6 21:07:29 ovpn-server1[2345]: 80.82.77.33:51598 TLS Error: TLS handshake failed
Dec 6 21:07:29 ovpn-server1[2345]: 80.82.77.33:51598 SIGUSR1[soft,tls-error] received, client-instance restarting
Dec 6 21:07:44 ovpn-server1[2345]: 80.82.77.33:43592 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Dec 6 21:07:44 ovpn-server1[2345]: 80.82.77.33:43592 TLS Error: TLS handshake failed
Dec 6 21:07:44 ovpn-server1[2345]: 80.82.77.33:43592 SIGUSR1[soft,tls-error] received, client-instance restarting
NEW RT-AX88U with Mirlin 384-19
