Hi
I'm using a RT-AC68U running Merlin. I noticed loads of lines like the following in my log yesterday:
Do these mean that someone is trying to access my VPN or is my system trying to access someone else's?
I turned my VPN off after I noticed these yesterday (rarely used and only by me) and I've not seen any entries in the log since.
Any help in understanding what is going on will be greatly appreciated. Cheers - Andy
Nov 14 16:35:40 ovpn-server1[11802]: 134.255.229.75 SIGUSR1[soft,tls-error] received, client-instance restarting
Nov 14 16:35:41 ovpn-server1[11802]: 134.255.229.75 TLS: Initial packet from [AF_INET6]::ffff:134.255.229.75:9987, sid=6a22eb44 5adb63fe
Nov 14 16:36:41 ovpn-server1[11802]: 134.255.229.75 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Nov 14 16:36:41 ovpn-server1[11802]: 134.255.229.75 TLS Error: TLS handshake failed
Nov 14 16:36:41 ovpn-server1[11802]: 134.255.229.75 SIGUSR1[soft,tls-error] received, client-instance restarting
Nov 14 16:47:51 ovpn-server1[11802]: 5.186.121.40 TLS: Initial packet from [AF_INET6]::ffff:5.186.121.40:1323, sid=6a22eb44 5adb63fe
Nov 14 16:48:51 ovpn-server1[11802]: 5.186.121.40 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Nov 14 16:48:51 ovpn-server1[11802]: 5.186.121.40 TLS Error: TLS handshake failed
Nov 14 16:48:51 ovpn-server1[11802]: 5.186.121.40 SIGUSR1[soft,tls-error] received, client-instance restarting
Nov 14 16:48:54 ovpn-server1[11802]: 5.186.121.40 TLS: Initial packet from [AF_INET6]::ffff:5.186.121.40:1323, sid=6a22eb44 5adb63fe
Nov 14 16:49:54 ovpn-server1[11802]: 5.186.121.40 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Nov 14 16:49:54 ovpn-server1[11802]: 5.186.121.40 TLS Error: TLS handshake failed
Nov 14
