Based on the information I read here, I got 2 units, for which are labeled as G.hn over coax gigabit Ethernet bridge (I believe moca 2.0). I could not find the Actiontec moca adapters in my country, so I got the only ones I could find.
However, I cant seem to get them to work. I waited for this weekend to try to setup the network using them. According to the salesmen it should be plug and play.
The instruction manual is really short and basic (I have attached a PDF)
Each of the units has the following ports:
- G.hn
- TV
-LAN 1
- LAN 2
Before trying to figure out which of the coax cables in the basement is the right for the room I want to set the connection with, I connected them with a short coax cable included in the package with each of the units, like this:
PC|LAN|-----cat5e--------|.....................................
......................................|cat5e............................
Unit 1| G.Hn ||TV||LAN1||LAN2|................
...................| coax..............................................
..................................|cat5e.............................
......Router| WAN||LAN |.............................
The connection I tried (and the units) look similar to this (but with 2 units only): https://shop.allnet.de/media/image/1d/a3/6b/123043_357bd7576dc4c1.jpg
LAN port led lights blink, but the G.hn LEDs do not. The PC indicates a LAN connection but no internet, nor can I connect to the router settings by tiping its IP address when connected trhogh the coax bridge.
I have to send this back by Tuesday so I could get my money back if it does not work. Am I doing something wrong?
- G.hn
- TV
-LAN 1
- LAN 2
