Help with Pihole on RT-AX88U
Col8eral
I'm having trouble getting Pihole to block adds on devices connected to my RT-AX88U.
My ASUS is running Merlin. The Pihole is running on an old Pi B plus model. I'm only using DNS on the Pihole. Not using DHCP.
The Pihole is showing URL requests and blocked sites but in reality when browsing the adds are still showing .
Mr router settings;
Under WAN settings:
Connect to DNS automatically = No
DNS server 1 = 1.1.1.1
DNS server 2 = 1.0.0.1
Under LAN DHCP Server:
DNS and WIN server setting DNS Server 1 and 2 = 192.168.1.41 (IP of Pihole)
Advertise routers IP = no
Under LAN/DNS filtering
Enable filtering = on
Global filter mode = Router
Then included Pihole in client list with no filtering.
On the Pihole DNS settings page
Upstream DNS server set to cloudfare
Enabled use conditional forwarding with the IP address of the router.
What am I doing wrong? Many thanks in advance.
bbunge
Part of the Furniture
Check your browsers to see if DoH is enabled. Remove the entry from LAN-DNS Server 2
Col8eral
Hi bbungei have removed from server 2.
On WAN prevent client from auto DoH is set to Auto. Is that correct?
bbunge
Yes. However, DoH can still be turned on. As for add blocking I use U Block Origin in the browser. My Pi-Hole uses Stubby for DoT/DNSSEC to Cloudflare Secure with malware on block lists. Pi-Hole will also block DoH from turning on.
Col8eral
It's strange, all my devices on my network are seeing adds. I just don't know what I'm doing wrong. Pihole shows all the queries but browsing the web I get adds every where.
I'm using the default Pihole blocklist.
Do you it's my router or the Pihole.what should my Pihole settings look like under settings/DNS?
