Help with Script in Asus rt n66u
crisidoani
Hello!! it´s the first time that write here, and i´m sorry for my english :)
I want change my actual neutral router Linksys wrt54gl for the asus rt n66u
I have configured all like the old one but i have one thing that i don´t know how do it
I have one script that execute every 15 minutes to check if any dispositive is conected to the wireless router and if there isn´t anything switch off the wifi
I want do the same in Asus but i don´t know how modify this script, in asus router have to wifi 2,4 and 5 ..... i don´t know, someone can help me??
Thank you
#!/bin/sh
wlclients=`wl assoclist | wc -l`
if [ $wlclients -lt 1 ]
then
/sbin/radio off
fi
Specify the interface to select which band you are querying:
wl -i eth1 assoclist
wl -i eth2 assoclist
However, stock firmware does not provide any way to have a script automatically run at boot time, you will need to install a third party firmware to be able to automatically have the cron job set at boot time.
Specifically what doesn't work? The two commands I gave you definitely do work on the RT-N66U.
Yes, I'm sorry, I have replaced wl by assoclist by wl -i eth1 assoclist in the
script but I don't get that Wifi 2,4 switch off
I'm trying with tomato firmware to execute the script every 15 minutes
Make sure that /sbin/radio does exist. I don't know if it's in Tomato (or even if it works - try manually running it to confirm).
The script that I wrote is working now I Linksys wrt54gl, with tomato firmware,
How can test manually? By telnet? I'm sorry, I'm not a expert
Thank you for all
