yayCollie
Hey, I hope this is the right section of the forum.
I replaced my ISP's router/modem when we switched over to a different ISP, I bought the ASUS RT-AC3100, along with 2 RT-AC68U, I planned on using the 2 AC68U's for a mesh network as they came as a bundle for a decent price. For awhile there hadn't been any issue's
Although I still don't think the transmissions are optimal, the ISP's fiber interpreter is in the basement and I don't have any CAT cable wired anywhere in the house, so my parent router is stuck in the basement. I had put an AC68U on the first and second floor for the mesh network. As I said it was fine for awhile, and then at one point somehow the fiber optic line got messed with somewhere in the neighborhood, and it eventually got fixed. After a couple weeks from that I had an issue where the RAM or possibly the storage of the AC3100 was full and kept trying to write something too it (it was fully updated and everything), I ended up factory resetting it and the mesh nodes. Again another couple weeks it was fine, but now I'm dealing with random droppage where the nodes on both floors (and potentially the parent router, I haven't confirmed that) are disconnecting from the Internet. I started digging around the system log's more everytime it happens and tried finding out what the cause to be.
Potentially I think it's a hardware issue (I might've bought these used, I can't remember), or maybe a power issue, I was going to try getting a UPS for the parent router. I'm not sure what to do as I can't find any real culprit, I wonder if it's because of multiple reasons.
I don't know how mesh technologies work so much, Would my node on the second floor need to have direct access to the parent router, or is it fine just routing through the first floor node, if its the first thing than it's probably experiencing issues due to how far the signal is from it, but then also the node on the first floor is having issues as well and there shouldn't be issue's really. I just wish my mom would let us have CAT wired through the house lol.
Anyways, if anyone has any ideas or things I can do to test that'd be great. Also maybe I should buy a newer ASUS router?
