Hi guys,need a help about stubby logging thru SSH
doublehd
How I can disable the stubby logging (stubby -l) ? my router's syslog full of those msgs..Thanks for it.
Change log level on stubby
# uci set stubby.global.log_level='2'
# uci commit
# /etc/init.d/stubby restart
Stubby should not be logging unless you enabled it.
Indeed.
From one of Dave's earlier posts:
To disable:
Bash:
nvram unset stubby_debug
service restart_stubby
Although I don't know why the output would end up in the syslog rather than its own log file. It looks like the OP has intentionally enabled logging but via a different method.
Those don't look like asuswrt commands. They look like OpenWRT commands. Did you try them? Did it work?
so I should stay put ?
Indeed.
argh,I was just key in "stubby -l" from SSH,and saw those msgs rolling from it should be.I then exited SSH.But it turns out those msgs found in the router's syslog...gosh.Thanks colin,will kick myself to fix it.
Just reboot the router and they should stop, if they didn't do so when you logged out of SSH.
When you run stubby -l from the command line the output will go to the sys log. Ctrl + c will stop the logging. Any other means of restarting Stubby will stop logging.
I did pressed ctrl+c but no luck.It just seemed to be activated the logging on router lol.
No, i did some googling for him, thought that would point him in the direction he needed to go. Apologies if it mislead.
