High CPU usage 40-95%
Andrej
Hi Everyone,
I have upgraded to 380.69 and since then my router started to act weirdly. For some reason, it is constantly using the cpu somewhere between 30-95%. I thought that it was due to an update but then I tried to flash older firmware but the problem persisted.
I thought the bottleneck might be in one of my devices. So I have switched off all ethernet connections apart from one that was used to connect to web interface, and disabled wifi networks the problem remained.
Could someone please advice me or point to a direction to review what is causing this behaviour. As some times it becomes so slow that I can't even connect to the web interface nor access the internet.
Here is example of my graph
https://i.imgur.com/PfNlwqw.gifv
Thank you in advance.
