foosion
Over a decade ago I got my parents a Linksys WRT54G (or maybe GL). It has worked continuously since then, but appears to have died today. The only current use is to connect some Wyze security cameras at 2.4ghz. to the internet. The router would be connected over a wired connection to a cable modem. We need something that is very easy to set up, preferably over wifi as they no longer have a computer, and will keep working without attention for years.
What would you suggest?
