Historical bandwidth statistics and real-time stats per IP not working
For the love of all that is Holy, folks, do NOT open the webui to the WAN... Even if I plugged that hole in 380.64_2, I do not trust the rest of the code not to have some other vulnerabilities that have yet to be discovered.
I had it open just for two days during troubleshooting, so that I could reach it from work. Guessing there is a quite known vulnerability since it is most likely that the vuln in my router was found while scanning large IP ranges. Anyway, not an issue for me since it can all be done through a VPN tunnel instead.
What about the IPtraffic issue? Any ideas? Anything to look for? Everything except for IPTraffic is working fine now - but IPtraffic was the main reason to go for the Merlin release.
I have experienced problems with a N66R not creating the data files on a USB. My fix was to go back to Merlin 380.57 and set up the traffic to the USB. Once it was working I upgraded to 380.64 and the traffic monitoring kept working. Do not have that problem with my RT-AC66U_B1.
I was able to get the Traffic Monitoring to work on my N66R running 380.65 Beta2.
After a factory reset and basic config, I formatted a 4 GIG thumbdrive with FAT32 and left the volume label blank.
Inserted the USB into the N66R, Tools, Other Settings, Traffic history location - Custom Location, Save History Location - select and create a folder on the USB. Apply then reboot the router.
After reboot - Tools, Other Settings, Save History Location - Select and choose the folder you created (Note: the USB was SDB at first and SDA after reboot) check Create or Reset data files, Apply.
Go to traffic history, daily and you should have something. If you have enough space on the USB you may want to create a swap file. If you have another USB drive make sure SDA does not "spin down."
bb
Running latest stable, I found that just setting it to create new data file for Global traffic only will never work - you need to create new data files for BOTH Global and per IP stats then both files will get created ... FYI
