Hey folks,
just wanna get everyone’s advice on a small network I’m thinking of setting up.
Based in the UK and currently renovating an old house and the ceilings are down. The walls are solid brick and the Wi-Fi inside the house was poor before. I’m thinking while I have free access to run Ethernet cable it’s worth doing.
Plan is as follows -
Ethernet running from each room that needs it to a tp switch which is connected to the ISP provided router/modem. I’m thinking I should turn off the wireless function on the ISP router. Then using Poe injectors on two of the Ethernet lines from the switch that runs to two access points on the roof in one room upstairs and one downstairs.
would there be any issues with this I haven’t thought about ?
Lewis
Lewis
