HomePlug & Light Dimmers
Simon
I'm curious to know which model or which type of Light Dimmers will generate the least interference on HomePlug PowerLine network devices?
I was told more expensive models are "better" than the cheaper models...
Does LED, CFL, or incandescent make a difference?
Can you provide a link to a recommended dimmer switch and/or bulb combo?
Thanx
I have only anecdotal evidence that dimming a halogen floor lamp could reduce HomePlug throughput.
Far worse are small cellphone chargers and "wall-wart" power supplies.
I guess I'm not going to order it online then, and may just need to go to my local home improvement center and/or dept. store w/ good return policies and test a few of them in my particular environment to see which one is "best"...
Thanx for the quick response, thiggins & stevech.... :) Take care...
