sfx2000
Part of the Furniture
Theoretically it should work, but I'm asking the hive mind...
Home has two broadband connections and 4 roommates...
Connection 1 is TimeWarner Cable - they provide the Broadband/Cable GW device, and this is by Roommate #1
Connection 2 is ATT U-Verse - this is DSL, and roommates 2 and 3 pay for this...
Both terminate in a common living area, provide their own WiFi SSID, and broadband drop... they want to extended the hardlines up stairs... running ethernet really isn't an option from the common area to the bedrooms..
Thoughts here... setting up two pairs of HomePlugs - set A for Roommate 1, and set B (one primary with two secondaries) for Roommates 2 and 3
So basically two distribution systems over home plug - I know performance won't be great, but again, with the hive mind's experience, is this doable?
