My Dell Latitude 5400 laptop has a WD19 dock with an ethernet jack. I connect it to my home network, which has a few unmanaged switches. When the laptop is on, no issues. But when the laptop is off, after a few minutes, all traffic from the closest network switch is blocked.
Connectivity is instantly restored if I:
About a month ago, I bought a few Netgear 16-port unmanaged switches (GS316) and life was great until one of them mysteriously lost all connectivity and needed a powercycle to fix. I replaced the switch but then another switch had the same issue a week later. I then just returned all the switches and got similar switches from TP-Link (TL-SG116). I thought the issue was resolved but now this happens.
I JUST got the laptop/dock today so could the netgear failure be due to another device going into low-power mode? I only thought of the dock as the cause because it's the only new thing added to the network today. This is all very confusing.
Maybe I should switch back to my older non-green switches (fewer ports).
- Unplug Ethernet cable from dock or unplug the same cable from the switch port
or - Turn on laptop
