How can I access router in a semi-loop situation
xworm
Background/Limitations:
R7000 initiate PPPoE session
PC2 must connect with ONU via ethernet cable
My expectation:
PC2 can connect to R7000’s LAN (and thus can access Internet)
Now:
When R7000 WAN is disabled, PC2 can connect to R7000’s LAN
When R7000 WAN is enabled, packet loss rate is above 90% for connection between PC2 and R7000’s LAN
What I’ve tried:
Disable/Enable Spanning Tree on R7000
Allocate same/different subnet for R7000 and ONU
Any suggestion?
Now:
the simple answer here is you cant because the pc2 is in front of the nat of the router
the simple solution and the correct one is to connect pc2 to the lan ports of the r7000 or connect via wifi to the r7000
the way you have it set pc2 would connect directly to the internet and create its own pppoe session and have a separate ip address if your isp allows more than 1 connection at a time
Always reminds me of shooting oneself in the foot - this little piggy went to market - blam, this little piggy...
n+1 and reload..
the reason I think it possible is that I have a "grey" cable connecting ONU's LAN switch and R7000's LAN switch, so PC2 is connected to R7000's LAN switch in theory.
The simple solution and the correct one is to connect pc2 to the lan ports of the r7000 or connect via wifi to the r7000
That's a solution if I can change physical connection
My ISP doesn't allow more PPPoE session, that's why I have to consider connecting back to R7000
ok so what is doing the routing ? as if you have the r7000 basically working as an access point and a switch you have no router
thus you would be getting different wan ip addresses for the pc2 and what ever connects to the r7000
the ond is not a router and has no routing functions its not even a switch as such
what you need to do is connect the r7000 in router mode via its wan port to the ond and connect pc2 to the r7000 by lan or wireless
