How can i Blocked P2P on my RT-N66U
HorstG
Hello,
how can i block ALL P2P in the RT-N66U FW 374.32.
THX
Horst
You may try layer-7 filter which is included in asuswrt-merlin. Not sure it can be done from WebUI:
  1. load /lib/modules/2.6.22.19/kernel/net/netfilter/xt_layer7.ko module,
  2. write following iptables rule to post-firewall script:
    iptables -I FORWARD -m layer7 --l7proto bittorrent -j DROP
Sorry can you me explane for an German Noob!:o
1. How i load "load /lib/modules/2.6.22.19/kernel/net/netfilter/xt_layer7.ko module," ?
2. How i am find the "post-firewall script" ????
3. Can i delete the "iptables -I FORWARD -m layer7 --l7proto bittorrent -j DROP"
if i have trouble.
Thank You...
Horst
if i have trouble.
Thank You...
Horst
1. insmod /lib/modules/2.6.22.19/kernel/net/netfilter/xt_layer7.ko
2. under /jffs/scripts (you may need to create one yourself)
3. yes, you can use -D. eg. iptables -D INPUT -s 127.0.0.1 -p tcp --dport 111 -j ACCEPT
was the /xt_layer7.ko module removed in the latest version? Can't seem to find it where expected. Trying to add layer 7 filtering for youtube. Not sure any other easy ways of going about it.
TY... any alternative ways to block layer 7 traffic that you guys can think off... i need ip targeted filtering :(
