How can I do this using AsusWRT?
dwp
I have some client IoT thermometer devices where the firmware has the DNS server to be used set to a fixed IP address (in this case 114.114.114.114). This is used to get the IP address of a web component (in this case SMARTSERVER.EMAXTIME.CN) to which data is sent (mostly using UDP).
I want to redirect at least the UDP to a machine on my LAN so I can eliminate reliance upon a possibly disappearing web component.
What is the best way to accomplish this? It seems like I need something at the LAN router level that can intercept the DNS requests made to 114.114.114.114 and return the IP of my choice. But I have no idea whatsoever how/if I can accomplish this.
BTW - I have a GS-AX3000 router.
So thanks for any advice/tips.
For some reason I cannot post the following. So here it is as an image. Sorry...
Stock Asus firmware doesn't support user scripts (although there are some hacks) so any changes will be lost when the router reboots. You'd also need to be running your own DNS server or modify the router's hosts file.
Merlin's firmware already has the ability to redirect DNS built-in.
