muffintastic
How do I get this to work with Cloudflare DNS in the .conf file?
This is my current setting without it installed:
Using the Advanced menu commandHow do I get this to work with Cloudflare DNS in the .conf file?
DoT
unbound (pid 25177) is running... uptime: 3 days 07:43:28 version: 1.13.2 # Version=v1.13 Martineau update (Date Loaded by unbound_manager Thu Sep 2 14:28:35 DST 2021)
i = Update unbound and configuration ('/opt/var/lib/unbound/') l = Show unbound log entries (lo=Enable FULL Logging [log_level])
z = Remove unbound/unbound_manager v = View ('/opt/var/lib/unbound/') unbound Configuration (vx=Edit;vh=help)
x = Stop unbound vb = Backup current (/opt/var/lib/unbound/unbound.conf) Configuration [filename]
rl = Reload Configuration (Doesn't halt unbound) e.g. 'rl test1[.conf]' (Recovery use 'rl reset/user')
? = About Configuration oq = Query unbound Configuration option e.g 'oq verbosity' (ox=Set) e.g. 'ox log-queries yes'
sd = Show dnsmasq Statistics/Cache Size s = Show unbound Extended statistics (s=Summary Totals; sa=All; http://10.88.8.1:80/user1.asp)
adblock = Install Ad Block [uninstall | update | track]
DisableFirefoxDoH = Disable Firefox DoH [yes | no] youtube = Install YouTube Ad Block [uninstall | update]
Stubby = Enable Stubby Integration DoT = Enable DNS-over-TLS
firewall = Enable DNS Firewall [disable | ?]
bind = BIND unbound to WAN [debug | disable | debug show] vpn = BIND unbound to VPN {vpnid [debug]} | [disable | debug show] e.g. vpn 1
scribe = Enable scribe (syslog-ng) unbound logging ad = Analyse Diversion White/Block lists ([ file_name [type=adblock] ])
dnsmasq = Disable dnsmasq [disable | interfaces | nointerfaces] ea = Edit Ad Block Allowlist (eb=Blocklist; eca=Config-AllowSites; ecb=Config-BlockSites; el {Ad Block file})
dumpcache = [bootrest] (or Manually use restorecache after REBOOT) ca = Cache Size Optimisation [ min | calc ]
views = [? | uninstall] | {view_name [? | remove]} | {view_name [[type] domain_name[...] | IP_address[...]] [del]} ]
safesearch = Enable Safe Search [disable | status | ? ] e.g. redirect google.com to forcesafesearch.google.com
localhost = Add { domain_name {IP_address | del} }
dig = {domain} [time] Show dig info e.g. dig asciiart.com lookup = {domain} Show the name servers used for domain e.g. lookup asciiart.eu
dnsinfo = {dns} Show DNS Server e.g. dnsinfo dnssec = {url} Show DNSSEC Validation Chain e.g. dnssec www.snbforums.com
links = Show list of external URL links
[Enter] Leave Advanced Tools Menu
e = Exit Script [?]
A:Option ==> DoT
Do you want to ENABLE DoT with unbound?
Warning: This will DISABLE being able to be your own trusted Recursive DNS Resolver
So, do you STILL want to ENABLE DoT with unbound?
Reply 'y' or press [Enter] to skip
y
Enabling DoT with unbound now as a Forwarder.
22:12:26 Checking 'unbound.conf' etc. for valid Syntax.....
22:12:39 Saving unbound cache to '/opt/share/unbound/configs/cache.txt' msg.cache=872/327 rrset.cache=2665/1519
22:12:39 Requesting unbound (S61unbound) restart.....
Shutting down unbound... done.
Starting unbound... done.
22:12:49 Checking status, please wait.....
22:13:27 Restoring unbound cache from '/opt/share/unbound/configs/cache.txt' (2021-09-05 22:12:35) msg.cache=0/327 rrset.cache=32/1519
22:13:35 unbound OK
Router Configuration recommended pre-reqs status:
[✔] Swapfile=1048572 kB
[✔] DNS Filter=ON
[✔] DNS Filter=ROUTER
[✖] Warning WAN: Use local caching DNS server as system resolver=YES see http://10.88.8.1:80/Tools_OtherSettings.asp ->Advanced Tweaks and Hacks
[✔] Entware NTP server 'S77chronyd' is running
[✔] Enable DNS Rebind protection=NO
[✔] Enable DNSSEC support=NO
Options: Auto Reply='y' for User Selectable Options ('3 4 5') Ad Block,Performance Tweaks,Firefox DoH
[✔] Ad and Tracker Blocking (No. of Adblock domains=231417,Blocked Hosts=10,Allowlist=19,Blocked Country=6)
[✔] unbound CPU/Memory Performance tweaks
[✔] Firefox DNS-over-HTTPS (DoH) DISABLE/Blocker
[✔] DoT ENABLED. These third parties are used:
1.1.1.1@853#cloudflare-dns.com
1.0.0.1@853#cloudflare-dns.com
9.9.9.9@853#dns.quad9.net
149.112.112.112@853#dns.quad9.net
[✔] Router Graphical GUI statistics TAB installed
[✔] unbound-control FAST response ENABLED
[✔] YouTube Ad Blocking (Forcing to use YT IP 62.24.208.79, No. of YouTube Video Ad domains=135)
[✔] unbound 'views:' ENABLED (1 views)
[✔] Safe Search ENABLED (209 domains e.g. redirect "www.google.com" to "forcesafesearch.google.com")
unbound_manager
v
command to see what statements are uncommented etc.)unbound_manager
FAQ,unbound
to use DoT isn't necessary as you can simply use the GUI options as you posted together with dnsmasq
, thereby making unbound
redundant.THIS ^.configuringunbound
to use DoT isn't necessary as you can simply use the GUI options as you posted together withdnsmasq
, thereby makingunbound
redundant.
Welcome To SNBForums
