How come I have two 5GH SSID?
yonghong
My router is N66U , I don't know what happened, one ssid is Yong-5G ,another is Yong-5G 2, how can I delete the second one, I tried both are working. Can you help me please? Thanks.
You could try looking under "Guest Networks" and see if you have one by that name that's enabled. If so, just disable it *smile*.
Are you sure it's not a network that was saved but isn't being broadcast anymore?
Use a tool such as InSSIDer to see what SSIDs are actually being broadcast, and also from which MAC address.
If you don't know how you ended up with two SSID. Simple quick way is to reset the router to factory default and reconfigure. And see what happens.
