How do 3+ MoCA adapters communicate?
scottyja
So thanks to some users here I discovered MoCA and think it will work well in my case. The only part I don't understand is how more than 2 adapters communicate.
I'm assuming the basic setup would be:
- Comcast from outside to cable modem (coax)
- Cable modem to wireless router (cat5e)
- Wireless router to MoCA adapter (cat5e)
- MoCA adapter to wall port (coax)
<internal wall>
- Wall port in basement to MoCA adapter (coax)
- MoCA adapter to switch (cat5e)
However, if I wanted a 3rd location to be in the mix, how would all 3 communicate with each other. If I used a conventional splitter (with 1xIN and 2xOUT), the 2 OUTs wouldn't be able to communicate with each other, would they? Even if there were more OUT ports, there would only be 1:n communication.
Anyone successfully using 3+ MoCA adapters?
I think I found the answer here. Looks like the OUT portions of the splitter are made to communicate with each other, so I would have to buy a 3 or 4 way splitter.
Anyone know if I would be able to send an OTA antenna signal from one of the MoCA adapters to the other without interfering with the existing signal?
MoCA 1.1 allows for 16 nodes.
Beware difference between a "splitter" and a "power divider". The former does propagate a sign backwards, from one of the output ports to the input port.
So if I'm just using the 3 OUT ports for each MoCA device to communicate with each other (no Satellite or Cable TV in the house), would it matter if I got a splitter vs. a power divider? This is the one I was looking at on amazon. I'm assuming it will work.
Sorry, I don't know. I do know that it's way overpriced as is all brand name "Monster" stuff.
