Hello! I have an Asus N66 router with the latest Tomato Shibby firmware installed. Everything is working perfectly but I'm wondering if there are any options or settings I should change in order to get the best speed possible and/or the most secure network possible.
Default is usually best. Unless you have an explicit reason for changing it, I wouldn't.
One of the major sins of computing is premature optimization. You can cause more problems (I have been guilty of this for the past 10+ years until recently) when you try to fix something that isn't broken.
If you absolutely must start tweaking the settings, only change 1 thing at a time and always reboot the router to confirm that the settings have taken effect. Go about it cautiously.
The following thread may interest you, so that you can see what the RT-N66U is capable of.
http://forums.smallnetbuilder.com/showthread.php?t=21139
You probably won't get much good out of raising the power level...I have not...it is a problem of having a big mouth but no ears.Right! I vaguely remember that setting. What's a good transmit power upper limit to keep in mind so that I don't accidentally destroy my router one way or another? 100? 200? Also I live in Sweden and the region is set to USA. Should I leave it at USA or should I change it to Sweden? Can the router get damaged by leaving it at USA?
Welcome To SNBForums
