I've done a lot of searching and reading but I haven't been able to figure out a clear answer to this question. I have an RT-AC68U router running 378.55 (because it's stable and I haven't needed to upgrade).
I'd like to be able to prevent clients on the guest wifi from being able to communicate with each other. I did a quick test, and right now guest network clients can see each other.
"Set AP Isolated" under the Professional tab affects both the guest and non-guest networks, and I'd prefer not to isolate wifi clients on the non-guest network.
Is there any way to do this via command line? Is there some other way to do it? Setting up a bunch of guest SSIDs is something I'd like to avoid.
Thanks!
Thanks!
