How do I remove entware?
Noremacyug
Subject says it. I've played around with it and can't get out of it what I want. Just want to remove it.
Sent from my iPhone using Tapatalk 2
Should not be to hard:
- Remove the start commands from /jffs/scripts and/or the script_usbumount & script_usbmount variable from NVRAM - basically reverse what you have done to install. :rolleyes:
- Reboot!
- Delete the Optware folder where Optware was installed
And Entware should be gone!
With kind regards
Joe :cool:
- Reboot!
With kind regards
Joe :cool:
forgive my ignorance, but i followed a tutorial to install this, hence my not knowing the exact process to remove it.
what start commands would i be looking for? all that is listed in /jffs/scripts is
post-mount services-start services-stop
as for the nvram, where can i find it. this is all i see.
admin@AsusRouter:/# ls
bin cifs2 etc jffs mmc opt rom sbin tmp var
cifs1 dev home lib mnt proc root sys usr www
thanks again.
You need to look into(!) the scripts in the /jffs/scripts folder.
The commands will be:
[B]cd /jffs/scripts
ls
more post-mount[/B] - or any other script
And then you need to edit the scripts with vi or nano (as long as you have entware installed).
For NVRAM the command is nvram(!):
[B]nvram show[/B] - lists all nvram settings
[B]nvram get[/B] "keyword" - show the settings of the "keyword"
[B]nvram set[/B] "keyword" - sets the settings for "keyword"
[B]nvram commit[/B] - saves permanently the settings
With kind regards
Joe :cool:
i have the same problem. Not very familiar to Linux, playing around with Entware on a RT-AC66U.
With "entware-setup.sh" Installation was easy. A similar command for removing, at least to clean up all modifications done to the router, would be helpful.
it was the most crude way possible, but i finally just formatted the hdd i had entware on and then reflashed firmware and cleared out nvram. i know all of that wasn't necessary, but i'm anal and wanted all traces gone. :D
Entware sits on the external drive and it is only mounted+started from /jffs/scripts/ folder. Therefore removing of everything from /jffs/ folder and "entware" folder together with 6 text files from usb/hdd is enough also for paranoid man. :D
Very paranoid can still perform
nvram show | grep entware
and clear every item in the list by
nvram set 'item_name'=
It is not necessary to reflash a fw, it can't be affected by entware. ;)
