Voxel How do I set Orbi RBK50 to assign PiHole IP as DNS Server on all DHCP clients?
V25
I've followed W1lliam's steps here: http://www.snbforums.com/threads/r7800-wifi-router-login-dns-relay.50389/post-449238
The steps are for an r7800, but nuts and bolts seem to be compatible with my Orbi (running Voxel's v. 9.2.5.2.16SF-HW on both the RBR50 & RBS50).
All fine, but after rebooting per step 7 of those instructions, the /etc/init.d/net-lan file reverts back to "option dns $($CONFIG get lan_ipaddr)" instead of my confirmed modified saved file with "option dns 192.168.1.2"
(192.168.1.1 is my RBR50 gateway which is also my DHCP server, and 192.168.1.2 is the PiHole DNS).
All I'm trying to do is to have my PiHole DNS to not see all traffic as coming from my router.
Appreciate any help/ideas anyone has!
mith_y2k
If you are using Voxel you should save your configuration file on the external drive and then it restores it after reboot
V25
Ah, you're right. I completely forgot about the tmpfs overlay partitions as Voxel explained in the QuickStart.txt bundled with the FW images - Thanks for the reminder!
Confirmed. It worked once I put an ext4 formatted USB stick in the RBR50's USB port, and put a copy of the edited net-plan to /overlay/etc/init.d/ on that USB drive. Thanks!
