How do I write scripts?
  • Thread starter Thread starter Deleted member 78435
  • Start date Start date
D
Guest
Hi.
I've been around DDWRT and Asus routers a long time but a bit of a Noob for MerlinWRT.
In DDWRT I could set up different wireless VLANS (and also wired/ ethernet Vlans) and isolate them with simple script such as :
iptables -I FORWARD -i vlan+ -o vlan+ -j DROP
iptables -I FORWARD -i vlan+ -o vlan1 -j ACCEPT
iptables -I FORWARD -i vlan1 -o vlan+ -j ACCEPT
I learned that Merlin (Kudos - great job with that as I am just discovering) has amtm but how/ where does one write/ edit/ save firewall/ security and startup scripts ?
I think I posted under the wrong thread.
Dam noobs !
Check out the wiki for the different script hooks available.
A common mistake people make when coming from DD-WRT is assuming that their old scripts will work on Merlin-WRT. While some basic scripts will work with only minor modifications others simply cannot because DD-WRT and Merlin-WRT have different feature sets. There are also additional differences based on the specific model of router. Good luck.
Thank you so that was an eye opener. Unix Hmmm
Can anyone share scripts they use? Im not too familiar with Unix but with 10 fingers and two opposing thumbs I'm pretty good at copy and pasting.
Ok so I made a common mistake as I am extremely common (low as they come) but I have transferable skills (did I already mention 10 fingers which includes 2 opposing thumbs?) Can you give me some pointers or share samples as I am not familiar with MerlinWRT and want to shorten the learning curve and get this done efficiently as possible....no need to reinvent the wheel and that sort of thing...
It would be better if you could state a particular objective that you're trying to achieve. We could then try and create a script for it or there may already be one posted in the forums (use the Better Search function at the top of the page).
In your original post you mentioned VLANs. Asuswrt and Asuswrt-Merlin do not have VLAN support. They do have things like guest WiFi networks though.
General scripting tutorials are the same as any other Linux distribution and beyond the scope of a forum post. There are already internet sites that cover that, but bear in mind that the router router uses sh rather than bash (which has slight differences).
So the main issue is manipulating specific router functions. Almost none of these are documented and have only been found either by trial and error or by looking at the source code. Again, searching the forum is usually the best bet.
Hey Collin, thanks for your response. That's all good information. I wasn't aware that there was no VLAN support.
Yes I am aware of the guest WIFI function. From what I have found out so far (PLEASE CORRECT OR CONFIRM)
1. Guest WIFi on AsusWRT doesn't function well in terms of true client isolation from other clients and also from the intranet (LAN)
2. Guest WIFI on MerlinWRT is able to provide isolation client-to-client and from the intranet (LAN), Yes?
I also looked into YazFi. From what I understand:
3. YazFi is is able to provide isolation client-to-client and from the intranet (LAN), PLUS one is able to change IP subnet as well?
I am having an issue with #3 though....I am not using a VPN and I set up 3 guest networks in Yazfi with client isolation enables and both one way and two way "off", the DNS server was set to 1.1.1.3 and 1.0.0.3 but I am still able to ping the Lan and all the other guest networks...what gives?
You hit the nail on the heart with two statements which were " if you could state a particular objective that you're trying to achieve" and also "main issue is manipulating specific router functions"
What I am trying to achieve is a degree of security through isolation. What do I mean ? Well I wanted to create 2 VLANS to keep an NVR system isolated from the LAN and also WIFI clients isolated from each other and the LAN, but allow internet access. (I am able to do this with DDWRT but due to lack of proprietary drivers etc. the wireless performance of DDWRT sucks). Some of the guest users are IoT devices: (Nest thermostats, Ring cams and WIFI Power Sockets). Its been a long journey and I suspect and like many seekers I tried all the Opensource Routers Firmware's.....DDWRT was great for many things and I went through a learning curve....tried tweaking settings but then got stuck with the lack of proprietary WIFI drivers and not able to put up with the lack of WIFI performance. Got to MerlinWRT - and Eric has done beautiful job as well as all the contributors to the additional scripts (Jack ,lonely coder etc - thank all). MerlinWRT has great WIFI performance and additional features....to circumvent the VLAN stuff I can always try to segment my network earlier but I am having issues now with YazFi. Despite my setup I can ping every client and vice versa.
As for network layout:
1. ISP MODEM (RTR. MODE/ DHCP) > NG FIREWALL/ UTM (TRANS MODE) > SWITCH for PC/NAS > WIFI ROUTER (DBL NAT)
2. ISP MODEM (BRG. MODE) > NG FIREWALL/ UTM > SWITCH > WIFI ROUTER (DBL NAT)
3. ISP MODEM > [VLAN SWITCH] >NG FIREWALL/ UTM > SWITCH for PC/NAS
4. ISP MODEM > NG FIREWALL/ UTM > SWITCH for PC/NAS
5. ISP MODEM > WIFI ROUTER > NG FIREWALL/ UTM > SWITCH for PC/NAS
My ISP gives me a single IP so cant really split it at the ISP modem...Out of these layouts I am using #1 BUT Thinking of switching to #5 with the rationale that the PC/ NAS resources need the most protection and Routers are Notoriously easy to hack with various MITM hacks and Exploits. I really would like some feedback and comments from you and anyone in the group who would care to chime in.
