How is this possible? (WAN IP outside of DHCP range)
dave__
Hi everyone,
How is it possible that my RT-N66U has a WAN IP outside of the DHCP range that my modem is set to?
Here's a little background on my setup:
AT&T Uverse NVG510 Modem
-IP Passthrough enabled
-Wifi disabled
ASUS RT-N66U
-Installed Merlin 374.40 last night
-Just did a 30/30/30
-WAN is configured for "Automatic"
-Unit is in "Wireless Router" mode
My concern is that my RT-N66U has a WAN IP of 108.218.34.62. However, my modem has a set DHCP range of 192.168.0.1 to 192.168.0.1 (in other words, there is no range, only one IP available).
I currently have internet connectivity but am confused how the RT-N66U has a WAN IP outside of the DHCP range that the modem is handing out?
I"ve attached a couple of config screenshots below to help visualize.
Thanks!
Dave
You're getting yourself confused.
The 192.168.1.1 address is not a public (WAN) address, it is a private LAN address.
There is nothing wrong with your setup. It is working as you've selected by setting it up in Bridge Mode (IP Passthrough enabled).
My guess is that this
is the key.
Your RT-N66U most likely gets the IP address from the ISP DHCP server, the modem has no external IP (since it is set to passthrough). It does have a LAN IP so you can access the web ui.
is the key.
Ok, great. I guess I was confused as I thought that the modem was supposed to give the router an IP within its DHCP range.
I did double-check and the WAN IP my router has is the public IP on my AT&T Modem.
Thanks for taking a look!
Dave
D Asus RT-AC86U Dual Wan and IPV6 ASUS N Routers & Adapters 8
