how make swap on asus wrt merlin?
Interesting. Could you post the complete output from 'fdisk -l'? I suspect you still have the remnants of the original FAT16 MBR or partition table still on that stick.It is interesting, because following the detailed instructions from here I obtained swap file and everything seems working, but fdisk -l shows FAT16 system at my USB stick
But mount command correctly displays ext2.
Fdisk bug?
Nah, it's not possible: I formatted everything within ASUS console. And yes - dd command was the same.I see it, and I agree with you, but I don't have an explanation. I still suspect there are remnants of its previous life. Perhaps format it on another device, using something like MiniTool Partition Wizard? Or search out the proper command to explicitly erase the partition table (dd ...). Or just ignore it, if its working OK for you.
I think you'd be hard pressed to convince anyone there's a bug in fdisk, or at least one worth fixing. That's an old, very basic command.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
