how to add a RT-AC66R to my network
SuperMiguel
So i just got a RT-AC66R for my house and i want to incorporate this router to my home network: http://i.imgur.com/ziTiPt1.jpg so thats howw i have it now i want to replace the Apple router with that Asus router, the thing i want to move that Time capsule to my back yard so i can have more range.. How can i keep a single SSID??? like how can i extend my RT-ac66r signal with the time capsule router???
Also whats the best mini pci-e card for my laptop that supports ac???
Just replace the Time Capsule with the RT-AC66R. You will then have to use the Time Capsule as an access point:
http://www.smallnetbuilder.com/wire...onvert-a-wireless-router-into-an-access-point
That's an old article, but basically you want to turn off the TC's DHCP server and most other services. I don't have any experience with Apple routers but I understand they are somewhat restrictive as to what you can control so you may have a few issues here.
This AP must be wired to your router somehow. Cat5e is the best but may involve running wires into walls, installing junction boxes, etc. Powerline networking may be your best bet - both your router and your AP must be plugged into your power connection so it should be available.
Don't try "wireless repeating". You will get a good signal but halve the speed.
I don't believe there are any mini PCIe cards supporting 802.11ac yet - there's that extremely expensive PCIe card from ASUS and a bunch of USB ones but no mini PCIe.
sman Network upgrade to the new wifi 7 and VLAN Wi-Fi Buying Advice 19
