how to add such a static route in the web interface ?!
CrashXRu
route -n add -net 192.168.99.0 netmask 255.255.255.0 ppp5
you need to see the network for nat when connected via pptp vpn
it is inconvenient to execute this command every time I connect to vpn
Incase it helps, I added a static route in the OpenVPN client config from my router (192.168.1.1) to my modem (192.168.8.1) in order to work with 'force internet traffic through tunnel: yes', by adding this line at the end of the custom config:
route 192.168.8.1 255.255.255.255 net_gateway
you did not understand,
I need to add a route using the web interface
how to do it in the SSH know
BUT
Linux has such options
ip-up-script / tmp / ppp / vpnc-ip-up
ip-down-script / tmp / ppp / vpnc-ip-down
ip-pre-up-script / tmp / ppp / vpnc-ip-pre-up
auth-fail-script / tmp / ppp / vpnc-auth-fail
but in the router there is no such possibility
I also can't figure out how to add static routes to the web, the ones that I write with my hands in the ssh
