everytime after reboot or change setting the led will turn on again, is it possible to keep the led turn off after reboot or change setting?
Ha Ha, really good idea...Sure... black vinyl electrical tape!
OE
I had 86U and 68U and both don't have that option, I know merlin got it but seems not for the offical firmwareMy 86U has a switch on the back to turn off LED lights, and in Tools > Other Settings, there is a Stealth Mode (all LEDS off) option. You might check those since we do not know what reouter you have.
The switch work but everytime after reboot or change any setting it will turn on again, that's the problem.Stock firmware does not have it...but
You had a 68u and did not have the switch on the back?
https://www.asus.com/support/FAQ/1004408/
Both of my routers have this switch.
Welcome To SNBForums
