How to best create local dns entries for static IP hosts?
5mall5nail5
Hey guys - I added entries to /etc/hosts on my AC66u with Merlin firmware, but at reboot it lost the changes.
Is there a better way to preserve DNS entries for internal hosts?
Thanks,
Jon
Thanks,
Jon
Put the entries in a hosts.add file on /jffs/configs. This will add those entries to the hosts file on reboot.
some of the community scripts rely on hosts.add and may overwrite it, i think it would be better practice to use dnsmasq.conf.add with;
addn-hosts=/jffs/extrahostsfile
and make your own additions there
Ok I think I got it working.
Only drag is I don't see the name resolve under the "clients" link on Network Map.
Anyway to remedy that?
Sounds like your very best option would be to forget everything above and set static DHCP reservations in the webui with host names. The host names will be pushed to the clients with the DHCP information and dnsmasq will respond to the host names for lookups.
So I'd need to extend my DHCP scope down to where my static hosts are though, yeah? Right now I have my scope start at 192.168.50.100 and my static IPs are from 192.168.50.1 - 53 (with some gaps, but I definitely have about 12 - 15 static IPs). Would I want to set the reservation first? Can I even do that? I don't want to risk other clients getting the IPs I want to hold.
No need to extend the range. My DHCP is 10.10.10.100-254 but my statics are below 100.
Ok so that works well, I have hostname resolution but I have some ordinary DHCP clients that only show up as MAC. For instance, my ipad shows up by its name but my wifes iphone shows up by MAC. Any thoughts?
Did you add dhcp-option=lan,44,x.x.x.x where x.x.x.x is the router's ip and Set as WINS server to Yes?
Listing your dnsmasq.conf here would be helpful.
No i've not made any entries in the dhcp config only added the MAC's in reservations through the web front end.
is dnsmasq.conf under /etc? same for dhcp conf?
Yes, as dhcp management is handled by dnsmasq.
If you created dnsmasq.conf.add under /jffs/configs, entries/options in that file would be appended to /etc/dnsmasq.conf so running
cat /etc/dnsmasq.conf
would list your entire dnsmasq and dhcp configuration for your router.
Did you fill the Default Gateway, DNS Server, WINS Server with the your router's IP and enabled <Force as Master Browser> and <Set As WINS Server> under USB Application / Network Place(Samba) Share / Cloud Disk?
None of this should be relevant because we're not talking about NETBIOS name resolution on the LAN. The client list is populated from DNS (AFAIK).
This should work without any problems (it does for my iphone), so the question is "why is the iphone not registering its hostname in DNS (via DHCP)?"
There could be a number of reasons but its probably because the phone hasn't registered itself with DHCP since you rebooted the router. So I'd start by checking the phones name in iTunes and making sure it doesn't have any non-alphanumeric characters.
Then delete the wifi profile on the phone and recreate it from scratch (using DHCP).
If that fails you could always create an IP reservation for it on the ASUS, then it will definitely have a name.
Under USB Application - Network Place(Samba) Share / Cloud Disk
Force as Master Browser is YES
Set as WINS server is YES
Under LAN - DHCP Server, DNS and WINS Server Setting
WINS Server: is blank
I'll pull dnsmasq tonight
Just noticed your post (hence the edit) - I beg to differ.. The client list is populated from several lists (DHCP,Custom,2g,5g etc.) and a network map scan function which then takes data gathered from the lists and merges it with the output of the network map scan... specifics in client_function.js
When contemplating solutions, I provide ones that cater to the variety of devices that could possibly be connected to a network. So while the client list/router may populate the hostnames of all connected devices, attempting to ping a client using its hostname from another client ie. windows, NAS etc. may still fail due to a NETBIOS/WINS dependency or incompatibility with dnsmasq due to an incomplete/half baked configuration and/or bugs with the firmware.
Enter your router's IP in the WINS Server field, apply and reboot. Reconnect all clients and verify. If the issue still persists, rename your wife's iphone to some new name (15 characters or less with no spaces), apply, reconnect wifi and verify.
Apple network enabled products are known to suffer from 'stuck' network profiles, dhcp client id and dns issues on wifi reconnect so recreating the current profile should help too.
Looking at client_function.js I can see nothing in there that suggests name resolution through WINS (although I may have just missed it) so we'll have to agree to differ on that point. :)
When contemplating solutions, I provide ones that cater to the variety of devices that could possibly be connected to a network...
I would agree with you that in general your suggestions are a good idea. However, in this case it looked like a lot of changes for the OP without actually addressing his problem.
FWIW, before making my first post I had recreated the problem on my network and the solution (for me at least) was to just delete and recreate the profile on the phone and thus force it to reregister with DHCP. YMMV of course. :)
