how to block a particular website
homeofwind
Hi all,
Using current stock firmware for AX86U.
Tried to block a certain site but seems it can be still accessed while some others can not. Any clean way of doing it through the settings?
I put the website on blacklist of URL filter and Keyword filter. Is it due to not cleaning the cache/data from the user end?
Any suggestions?
Thanks!
Hi all,
Any suggestions?
Thanks!
Did you tick the "enable" button? After ticking the enable button, you need to add the site to the URL Filter - blacklist. After adding items to the list, you also need to hit the "Apply" button when you're finished.
