How to block some home networked pc's from only internet access?
cooa99
Hi all,
I have a couple of virtual machines running on a headless windows 10 & Apple Mac mini pc in bridge mode, so access to the physical Home network. I can access them using vnc,Remote Desktop connection and the browser for some that have http related services.
The vm's themselves don't need internet access since I connect to them from within my home network which is using n Asus DSL AC68U router. I am worried the internet access posses a security treat considering some of those vm's are almost 10yrs old.
My question is How do I stop them from accessing the internet yet be fully functional within the home network?.
Is this to be down from within the router settings or/and the vm's themselves?
If your VM NICs are bridged, remove their default gateway to prevent them from being able to connect outside of your LAN.
@RMerlin , This worked but the only way I could do it was to change the vm from DHCP to static IP address and omit the default gateway.
I take it doing the same on a DHCP vm is not so straight forward?
While on subject of security, Am I better off converting the NIC of the VM's from bridged to NAT?
You would need to have a configurable DHCP server where you can chose the gateway to provide to specific clients.
If you worry about inbound connections coming from your LAN, this will provide a layer of security. But otherwise, I see no real point in doing so, unless you intend to have a host-local network between the VMs.
As RMerlin mentioned: removing the DGW (default gateway) is a quick way to go. But I have some ideas which might help too:
- what about firewall (directly on the OS level or via router or a main-firewall)?
- DNS restrictions (may be DNS Filter)?
