amtm how to change the default curl located in /usr/sbin?
saccleo
How to change amtm's default curl from '/usr/sbin/curl' to '/opt/bin/curl'?
Or how to set a socks proxy for the '/usr/sbin/curl'?
For some reason, amtm can not install addons except using an socks proxy.
This appears to be something specific to your situation (as nobody else has reported this problem). So I'd suggest that you try and debug the issue before patching any code. Are you in a country that blocks access to certain websites?
Yes, 'raw.githubusercontent.com' is blocked. so i need curl using a proxy to pass through the firewall.
but the curl from the firmware seems does not support socks proxy.
