How to check RSSI on AImesh node?
DummyPLUG
I want to check RSSI on the AImesh node, I use the wl rssi command but it didn't work, what ever mac address I use it will only report the main aimesh node rssi, also assoclist only list other aimesh node.
any other way to check the RSSI without install other things on it?
UPDATE: I am too stupid, I had forget it now on wlx.x and I keep using eth1 and eth2... lesson learn, don't work at midnight :)
