Y
ysfm
Guest
hii
i just wanted to buy a new wirelss router,
while i was looking on the net, most of the new routers
use WLAN port for connection, while wat am i using
is ADSL router now, which has diffirent port, as u know
ADSL use phone line..
so , i was told that i can directly use a wire from my router
and use the wireless router as access point..
so if this is true, wats the difference will be between access point
and the router??
also , is there any other way, to connect the router directly??
thanx
and the router??
thanx
