How to Detect when Firmware is Updating via Script
copperhead
I need to pause a network monitor script during firmware updates to avoid interference. Is there a way for scripts to detect when a firmware update is being inspected / applied by the front-end UI?
Is the "network monitoring" script running on the router or elsewhere like on a server? If it's on the router it's much easier. How is it being triggered to run? Via cron job?
For example, MerlinAU stops all other cron jobs from other scripts and Entware processeses such as unbound and diversion, etc before unmounting the USB and starting the flash.
The internet monitoring script is running on the router. It is a python script which was launched by the post-mount event. The script remains active indefinitely checking the internet every 30 seconds in the following order:
1. Check Internet:
x Performs ping test
x Checks DNS resolution
** If any of the above fail then ....
2. Try to Fix Internet connectivity. The script runs through each of the following checking the internet status at each level. If the internet is restored, the function is exited and the script goes back to Sleep for 30 secs then, when awake, restarts at (1) - Check Internet:
x Attempts DNS fix.
x Renews ISP DHCP lease
x Restarts WAN interface
x Restarts router
x Restarts modem
My concern has to do with when the router is checking / applying its firmware. The last time i updated the firmware, I've received notifications from the script that the internet wasn't working. It got all the way down to "Restart WAN Interface". Thankfully it never got to the "Restart Router" stage which, to me, seems like a bad idea when firmware updating.
1. Check Internet:
x Attempts DNS fix.
x Restarts router
x Restarts modem
Well to answer your question; the "easiest" identifier for example would be in the system logs:
May  5 09:05:31 custom_script: Running /jffs/scripts/service-event (args: start upgrade)
May  5 09:05:30 rc_service: httpd 4893:notify_rc start_upgrade
Which can be identified with this shell command:
grep -i "start_upgrade" /tmp/syslog.log
In the case of MerlinAU with your python script, as long as the script is installed on the USB the process would be shutdown by MerlinAU's USB unmount or the entware unslung command (not sure where python is installed)
1. Check Internet:
x Attempts DNS fix.
x Restarts router
x Restarts modem
There is an even earlier process which is this one:
May 5 09:05:23 custom_script: Running /jffs/scripts/service-event (args: stop upgrade)
Which means when you start an upgrade, the service-event script is triggered with the event parameters: stop upgrade
You can piggy back on this if you'd like. when the service-event receives the "stop" and "upgrade" parameters; it can shutdown your python script.
That is perfect!
So i would use the service-event: stop upgrade to stop my python script. Got it. Not that i need it but out of curiosity, what event is issued when the upgrade is complete? Dont tell me it is service-event: start upgrade. That would really mess with my mind.
That is perfect!
Look inside the service_event script for existing examples; here is the one MerlinAU uses:
if echo "$2" | /bin/grep -q "MerlinAU" ; then { /jffs/scripts/MerlinAU.sh service_event "$@" & }; fi #MerlinAU#
So if the second parameter is "MerlinAU" then it passes all the original variables to the MerlinAU script when calling it.
But for your example, you would likely want to do something like:
if [ "$1" = "stop" ] && [ "$2" = "upgrade" ]; then
    PIDS="$(ps | grep '[p]ython .*/Test/test\.py' | awk '{print $1}')"
    if [ -n "$PIDS" ]; then
        # Graceful SIGTERM
        kill $PIDS 2>/dev/null
        sleep 2
        # Force‑kill any survivor
        for PID in $PIDS; do
            if kill -0 "$PID" 2>/dev/null; then
                kill -9 "$PID" 2>/dev/null
            fi
        done
    fi
fi
Remember that it's being passed as 2 parameters, one being "stop" or "start" and the other being "upgrade".
Think of it as the event calling the service-event script is the "upgrade" event. Why? Because It's "stopping" the services for the "upgrade" event.
It gets called again shortly after when the actual upgrade starts, but very clearly after the "stop" is issued if you look at the time stamps:
For your last question; the service-event is not triggered again once the upgrade is completed.
The router simply reboots. The next time you would see the service-event being triggered is post reboot when restarting the services.
Fantastic explanation. I have it all implemented now and verified. Much appreciated!
Happy to hear! And glad I could help point you in the right direction.
