How to enable custom script on AiMesh nodes?
helloguys
RT-AC86U, Merlin 386.1_2.
I want to enable custom scripts on AiMesh nodes. But when I put the node IP in web browser and login, it automatically redirects to the main router portal. In the node's log, I found the following, even though the main router has custom script enabled, which indicate this setting is not replicated to AiMesh nodes automatically.
[email protected]:/jffs/scripts# grep services-start /tmp/syslog.log*
/tmp/syslog.log:May 5 00:05:14 custom_script: Found services-start, but custom script execution is disabled!
How may I enable custom script on AiMesh node? Do I have to remove it from AiMesh, enable custom script and add it back in? Or is there an easier way(like, from CLI)? Thanks!
RMerlin
Asuswrt-Merlin dev
nvram set jffs2_scripts=1
nvram commit
