How to flash ASUS-RT-AX3000 ?
albertux
I have an ASUS RT-AX3000 with the current stock firmware: : 3.0.0.4.388_25210-gfbda585 I tried to flash using the RT-AX58U (based on the readme is the same firmware) "RT-AX58U_3004_388.9_2_puresqubi.w"
I even tried the:
nvram set DOWNGRADE_CHECK_PASS=1
But I always get:
Firmware upgrade unsuccessful. This may result from incorrect image or error transmission. Please check the version of firmware and try again.
Any help is appreciate it
Do you have a v2 version of the RT-AX58U? If so you will need to use the Gnuton fork that supports the RT-AX58U v2.
Hi bennor how do I know is V2 ?
nvram show | grep version
Ate_version=1.0
acs_version=2
bl_version=1.0.4.1
sd_feature=version
size: 76886 bytes (119722 left)
wl0_version=17.10.188.6401 (r808804)
wl1_version=17.10.188.6401 (r808804)
wl_version=17.10.188.6401 (r808804)
wps_version2=enabled
Check the lable on the back of the router, it typically will show version (H/W Ver) number if there is one.
Hey thank you again I can confirm is V2 I will try the gnuton firmware
