How to i configure this?
vnwind
HELP: How do i set this up?
Hi to every experts in this forum :-),
I am new to networking and this is my network layout
My question is what do i need to do so that my Remote Location PC can connect to my SQL SERVER
Thanks very much for your help or lead me to the right direction
Cheers
after further reading, maybe it is better i just get rid of the win 7 and install vpn client on Asus N66 router.
What do you think?
What do you think?
From a totally non-professional side , it does seem a bit 'overkill' to have a PC running the VPN routing when the router can do the donkeywork for you and free up the PC.
true, the reason i did it this way was because i did not know that i can have vpn pptp client install on this router.
Anyway, I followed this tutorial and get Fractal build DD-WRT on my router.
I set up the pptp server and client as following
VPN to router works great but there is no way i can tell if my VPN client works or not. I still can't see the SQL server from my remote PC
Can anyone point out what i am missing or my setting is wrong?
Initially I would suggest you need a static route on the remote PC for the 192.168.10.x subnet to be via the RT-N66U gateway otherwise it will just send the packet to its local default gateway (local internet connection)
When the packet gets to the ASUS it will unwrap the encapsulated packet and look for the destination, which in theory it will then pass to the VPN client connection for onward routing (so the ASUS will now be your source MAC address). If its handling the NAT properly between the VPN connections , it should be ok - but for further troubleshooting, I would initially plug in a machine directly to the ASUS and prove you can see the SQL server over that connection. What I'm not sure will happen is how the ASUS will handle re-encapsulating the packet back to the remote connection...
