Is there a way to install the RT n66u firmware through via. telent? If so, what are the exact steps to do so?
mtd-write -i /tmp/RT-N66U_3.0.0.3_108.trx -d linux
reboot
Not recommended for beginners, but if you must know:
First, copy the firmware to /tmp. Then, run the following commands (adjusting the firmware filename as needed):
Try putting the commands one at a time?
ARM routers have a different command, with a different syntax.
Code:mtd-write2 /mnt/sda1/file.trx linux && reboot
Welcome To SNBForums
