How to LED control - put your router in Stealth Mode by turning off all LEDs
Jgafa10
I'm new to wrt-merlin
I can't find any information on how to
  • LED control - put your router in Stealth Mode by turning off all LEDs
Is there any way to turn off my router RT-AC68U off automatically after I select a certain time or is that just the LED lights that go off? Can anyone direct were to find this information or YouTube tutorials.
Thank You
Tech9
Part of the Furniture
LED control only. No router on/off control. You can do wireless on/off, if you want to.
Jgafa10
Ok, where can I find where can I find the instructions on how to turn the LED lights ON/OFF. Thank you.
bennor
Since you indicated you are using a RT-AC68U, why not just use the LED On/Off button on the back of the router to turn off the LED's. Asus also has a support link for how to turn off the LED lights on their routers:
[Wireless Router] How to turn ON/OFF LED light of ASUS router?
If using the Asus-Merlin firmware on one's RT-AC68U, one can disable the LED's via the GUI > Administration > System > Disable LEDs.
