How to load iptables rpfilter module ?
Denna
How do you load the iptables rpfilter module in a script ?
Not available.....kernel is too old
"A new iptables/ip6tables match (rpfilter) was added in kernel 3.4.4"
Are the "/proc/sys/net/ipv4/conf/*/rp_filter" settings used by the firmware ?
What is the difference between setting the values in "/proc/sys/net/ipv4/conf/*/rp_filter" and using the netfilter module ?
Are the "/proc/sys/net/ipv4/conf/*/rp_filter" settings used in the Asuswrt-Merlin firmware ?
What are the "/proc/sys/net/ipv4/conf/*/rp_filter" settings used for in Asuswrt-Merlin ?
e.g. see /usr/sbin/vpnrouting.sh
# Unsure if necessary, but most policy-based routing scripts disable reverse path filtering
 for i in /proc/sys/net/ipv4/conf/*/rp_filter ; do
  echo 0 > $i
 done
@Martineau,
Is that code from @RMerlin or Asus ?​
Policy based routing is used to direct traffic for specific IP/MAC addresses to a particular VPN client on the router, correct ?
When configuring routing in this manner in the Asuswrt-Merlin WebGUI, that automatically changes all the "1" values to "0", correct ?​
