How to manually create a tap0 interface
Jeffrey Young
Good morning everyone.
I am trying to create a tap0 device to add to the br0 bridge so I can get to my network using Softethervpn. I am using this solution in order to get past the CGNET created by by ISP as Softethervpn uses a AZURE relay service.
I am trying to issue the following command, but I am getting a "
open: No such file or directory", which I am assuming is because there is no tap0 device.
ip tuntap add mode tap tap0
Does busy box have another means of adding a tap interface?
You may try:
ip tuntap add dev tap0 mod tap
Thanks, after some more reading and testing, it turned out that the tun.ko kernel module had not been loaded. I am guessing that the module is not loaded unless the internal OpenVPN server is used.
The tun0.ko module is hiding at /lib/modules/4.1.27/kernel/drivers/net/tun.ko
So, this finally worked;
modprobe /lib/modules/4.1.27/kernel/drivers/net/tun.ko
ip tntap add mode tap tap0
ip link set dev tap0 up
All that is left to do is add tap0 to the br0 bridge (have not tested yet), but should be something like this;
brctl addif br0 tap0
and adjust the br0_ifnames nvram entry.
Just not sure if I need to add any other nvram entries??? Any help here would be appreciated.
