How to rollback to stock firmware
royarcher
Can you simply flash the latest stock Asus firmware on say an RT AC 88 U running the latest Merlin firmware ( Uno the one ending in a 7) and then do a factory reset?
Or do I need to do something else first?
That's it. Make sure to do a factory reset with initialize. Then manually configure the router. Do not use a saved settings file.
