It's not possible to do via the WebUI as you cannot create an account without a password.I have a usb flash drive plug in AC1900P.
the drive have 2 folders:
entware
download
I just want to access the download folder via samba, dont want any one access entware folder
Samba is a b*tch to configure without a password and still restrict the access.
Think of other ways to share or figure it out using google's endless results.
As I said, it can be done using the mentioned ways to customize the conf file.It can be done with the smb.conf - I'd hesitate to try and tweak the conf file included with AsusWRT as it can break later on if touched inside the WebGUI..
That being said, adding/modifying "guest ok = yes" for the desired share should work, as Samba can do share level permissions.
Welcome To SNBForums
